anybody know the max page size? thinking about condesning all of the subpages from my website down to one scrollable feed on one page. I’m curious how long the page can be at its maximum. 50 lines? 100 lines? no max? will doing this increase lag? just curious, @angie maybe you know? TIA!
Hey you ![]()
Yeah, great question! There are no specific hard limits in terms of how many rows you can add, or if you want to set all your Subpages to Scroll instead of Swipe.
However, I will say: I don't think it performs the best. Unless you have Lightning McQueen-kachow-speed internet, there will always be a small but noticeable lag between the Subpages. It could also affect the way your data loads for viewers.
My Support girlies are always saying it's like a junk drawer- too much stuff, and it won't open or close smoothly. So unless your site is incredibly minimal, just keep that in mind, but of course experiment to see if you like it 🫶🏼
awesome, thanks!!
I went ahead and decided to send it and it seems to be working fairly well. There is a slight loading delay, but honestly it feels like it’s always been there.
Other than that it appears to be performing okay and I think i’m liking this layout a bit better than the multi-page style.
Amazing! Yeah, I just took a quick peek and it looks great ![]()
