Hey guys logo generation just dropped! Courtesy of releases.univer.se
The designer in your pocket has leveled up again: introducing image generation. Add an image block, select “Generate,” and use the magic of AI to create the perfect graphics to your site. Can’t find the right stock photo? Conjure up a unique image that reflects the vibe of your site. Looking for something more artistic? Generate consistent, sketch-like designs that give your site a hand-drawn feel. Need branding? Generate a logo for your brand—and use the background removal tool to create a transparent image you can use everywhere.
I was playing around with it and it came out pretty good! As a rule, I always just reword my prompt, to see if a better design is generated.
If you have removed the background to your logo and change your mind, you'll need to undo the edit before leaving the current session. Because it the background removal tool is a newer feature, there isn't a native "un-remove background" option at this time! ![]()
How do I Undo and Redo changes in Universe?
Have you checked out the Image Generation Tool yet? What were your thoughts? Let me know down below!
